Power Potential
Power Potential
Everything on my new motor is finalized, how much power y'all think it will hold with an s480?
414ci iorn block half filled
Lunati Pro Series Crank
Lunati Pro Series Rods
Diamond -22cc Turbo Pistons
Hell Fire Rings
ARP 9/16" head studs
ARP Main Studs
Cometic Gaskets
TFS Heads
GMPP Single plane
Shooting for 20-25 PSI
Hell Fire Rings
ARP Main Studs
Cometic Gaskets
TFS Heads
GMPP Single plane
Restricted User
Hell Fire Rings
ARP Main Studs
Cometic Gaskets
TFS Heads
GMPP Single plane
Hell Fire Rings
ARP Main Studs
Cometic Gaskets
TFS Heads
GMPP Single plane
and i already have the rotating assembly, the deal was too good to pass up
i agree on cube size for turbo as well.. if you got the money i guess spend it on a crank, but ive been 5.54 at 128 on stock stroke 6.0 crank... on 20boost.. and i believe 98z28cobrakiller has been in 5s as well..
