I want more! Procharge sbc?
Old 12-05-2010, 01:14 PM
dolf's Avatar
Default I want more! Procharge sbc?
I have a built 383 with 10.5 SCR that made 561 on the engine dyno. Well, I want more! I was thinking about a D1sc at 6-7 psi. Can I do this safely on 93 pump? I do have a good sized solid roller to bleed some pressure and efficient aluminum heads.
6" rod 383, forged short block
AFR 210 Elims. 10.5 SCR
Ed Rpm air gap, ported
Comp solid roller, 252/258 600/600 110
Pro systems carb
Would I need to run meth injection?
Old 12-05-2010, 04:43 PM
topend's Avatar
your cam cannot change your compression ratio. As far as running low boost you should be fine providing that you run 93 octane fuel with a decent intercooler.
Old 12-06-2010, 06:29 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Pro systems carb
You can easily run 8 psi with your compression ratio, the carb helps to cool down the inlet air temps and you won't need methanol injection. Give me a call for a great price for your SBC. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 12-06-2010, 11:26 AM
dolf's Avatar
How does the carb cool down inlet temps?
Old 12-06-2010, 11:38 AM
LS1Tech Sponsor
The intake manifold becomes a wet manifold with a carb, and the fuel going through it drops the inlet air temps. Bob
__________________
Quick Reply: I want more! Procharge sbc?
