Is this an OK turbo cam? XR269 216/220 525/532 114 lobe
Old 12-16-2010, 09:55 PM
fuzzyjk's Avatar
Default Is this an OK turbo cam? XR269 216/220 525/532 114 lobe
Will this cam be a good turbo cam? Here is my set up.
5.3 (L33)
Ported 799 heads
MPT70 set up for 10psi
Air to air intercooler
38mm wastegate
Vortech BOV
58 injectors
LS6 intake
These are the cam specs I was planning to use....Comp Cam XR269, 216/220 525/532 114 lsa
Old 12-17-2010, 10:07 AM
fuzzyjk's Avatar
Anyone?
Old 12-17-2010, 11:44 AM
Hank Peabody's Avatar
IVe got relatively close, a TU0 216/216 .561/.561 114, it works great in my 6.0 and 317 heads. Figure unless it is max effort most any small cam like that is going to work good, all going to be within a few horsepower, if there were any magical cams people would be sure to let us know so they'd sell more of them.
Old 12-20-2010, 08:12 AM
fuzzyjk's Avatar
Going to install on Tuesday night, is there a problem with using this cam? Is it to big? Not enough LSA?
Must be more than one person that might know the answer! Any help would be greatly appreciated.
Quick Reply: Is this an OK turbo cam? XR269 216/220 525/532 114 lobe
