Backpressure - Can big wastegates help?
Old 12-21-2010, 08:38 AM
TiAL's Avatar
Originally Posted by Louis at GSS
Drive pressure is related to boost pressure. To reach a set boost level, drive pressure must be what ever it is, to reach that. A wastegate regulates drive pressure, yes, but it still takes X drive pressure for the compressor to reach X boost level. Decreasing drive pressure by way of wastegate, only decreases boost level.
100% correct
Old 12-21-2010, 08:39 AM
turbo'd stang's Avatar
Anyone remember Halfacre's SSO car and them getting caught with a NOS solenoid? They claim it was plumbed into the hot side to bleed pressure as they went down track.
Anyone ever try something like this?
Old 12-21-2010, 09:07 AM
Restricted User
98Z28CobraKiller's Avatar
So they had the WG wideopen and still couldn't get the pressure out. LOL. Riiiiiiiiiiiiiight.
My guess would be that they were doing some sort of antilag, 2 step spool helper type activity with that noid.
Old 12-21-2010, 09:31 AM
Fireball's Avatar
Originally Posted by BoostnTBSS
So i should run a 38mm gate then!!! oh wait i can't cause i will get too much back pressure and boost creep!!!!I am not saying it is a cure but its a small factor!! all the other things add up like you said Lou.. if a ex housing flows 70lbs and a motor pushes 100 lbs there will be back pressure. now with a 38mm gate once open lets say it flow 15lbs and a 60 can flow 25lbs its a small factor. cause most run the gate back into the ex..
i guess we can all sell our big gates and run internal gates to save money....
go right on ahead and do that
Old 12-21-2010, 11:02 AM
TracyRR's Avatar
Thanks for all of the reply's!! I just ordered the larger T3 .82 housings.... that is the largest i can get with the v-band. I'll update with some numbers later.
Old 12-21-2010, 11:52 AM
7 Second Club
Phil99vette's Avatar
Or the turbo was maxed out since its a turbo limited class and thats the only they could make more power...
Old 12-21-2010, 11:53 AM
7 Second Club
Are you using T3/T4 turbos? What size motor?
Old 12-21-2010, 12:50 PM
TracyRR's Avatar
Yes, they are t3/t4's. 370ci
Old 12-21-2010, 12:53 PM
7 Second Club
What did you do for heat retention since the turbos are soooo far back? What size headers and tubes do you have going to the turbos?
Old 12-21-2010, 01:00 PM
TracyRR's Avatar
The manifolds and the complete exhaust are wrapped up real well.... some of it is double wrapped. The exhaust is 2.5" duals all the way to each turbo in the rear. I was wondering what effect spool would have if i downsized the exhaust to 2 or 2.25 duals to the turbo's?
Old 12-21-2010, 01:31 PM
7 Second Club
Basically your transporting the air from the end of the header to the inlet of the turbo, the smallest point in the exhaust is still going to be the turbine housing. I do not think that 2" tubes between the header and the turbo would hurt performance. On a 370" at 20# of boost you would see a max air speed of 550cfm which is in the acceptable area. It would probably spool faster also.
On my 450+" LS motor, we're going to continue to use a 2.5" tube between the header and turbo feeding a 3.5" tube into the turbo. Game plan is to make well into the 2xxxhp range, or enough hp to go 175-180mph to the 1/8 mile.
On your car it would be interesting to see how a set of 1 5/8" stepped to 1 1/2" somewhat equal length headers would work.
Old 12-21-2010, 01:38 PM
  #32
TracyRR's Avatar
great info phil, i may try to decrease the size of the rear section (over the axle) exhaust that bolts to the turbo to see if it spools quicker. If that works, i'll keep working towards the motor to see if i can improve it even more. Thanks!
Wow, you are going to be flying!! You are an asset to the board, thanks for the help! tracy
Old 12-21-2010, 03:45 PM
  #33
tripblackls1's Avatar
i somewhat disagree with this
it would be good logic if you had completely straight exhaust pipes, but with every bend in your exhaust your increasing restrictions, so even with lets say the smallest area in the turbine is 1.5" then a 15ft of 2.5 pipe with 3-4 90 degree bends would flow about equal of 1.5" restriction in the turbine, now if you have 2" pipe with your just adding more restrictions with every bend decreasing flow before you even get to the main restriction
now this is just an example
(if i was at work i have actually flow charts for pipe and bends and etc..)
in my opinion it would be best to keep the 2.5 pipe
Old 12-21-2010, 04:01 PM
  #34
7 Second Club
So in your opinion, what size should be used if you were building a 450" LS motor that was going to make 2700-2800hp? Header, crossover and merge? 2 1/4, dual 3.5"?
Old 12-21-2010, 04:11 PM
  #35
is it going to be a rear mount?
because if its a front mount there is a lot more variables involved ( such as heat, density and velocity ect..)
with rear mounts i do see flow restrictions being a problem
but i doubt your doing a rear mount and trying to make 2800 hp
Old 12-21-2010, 04:55 PM
  #36
7 Second Club
Front mount...I'm curious to hear what sizes would be optimal.
Old 12-22-2010, 06:26 AM
  #37
crashly's Avatar
phil,
are you saying your going to step the headers from 1 5/8 down to 1 1/2 , before the collecter ?
Old 12-22-2010, 08:16 AM
  #38
7 Second Club
Originally Posted by crashly
phil,
Yep, it would be something interesting to try and I'm fairly confident it would work exceptionally well.
Old 12-22-2010, 09:03 AM
  #39
crashly's Avatar
ok,
ive asked a certain person about this sort of stuff. Was an interesting conversation, as always.
ash
Old 12-22-2010, 09:05 AM
  #40
7 Second Club
ok,
ash
And.....what did he say? Did it end with "he is full of ****"? LOL!
Quick Reply: Backpressure - Can big wastegates help?
