ls6 install grey rtv around ports???
i just got a boosted car and pulled the ls1 intake off to put a ls6 on. when i pulled it off the owner befor put grey rtv all over the ports? do i need to do the same for the ls6? or will the new port gasket set on the ls6 keep it from leaking bost just fine? also found grey rtv on all of the injectors? is all this rtv unesesary? thanks guys. im only running 7 psi.
