Ebay gt45 turbo on a 6.0 lsx
A MPT70 could make around 600hp but that'll be about it. If you're not afraid of the power coming in a bit slower, and if you have room under the hood I'd go for the BW unit. They can be had for about $550 and are nearly bulletproof. Plus if you want more power in the future, no need to upgrade.
Also search for some 60lb injectors ("Mototron" seem to be the standard), dual Walbro pumps for safety. Rising rate FPR, return lines, etc. Oil lines, better head gaskets and fasteners, etc. It all adds up. Just FYI.
Yea at first I was told to get a master power t70 because they weren't that high. I see lots of people running mp turbos with lsx mills and making good power! What size bov and wastegate should I use?
[QUOTE=HydroStream6;14698575]A MPT70 could make around 600hp but that'll be about it. If you're not afraid of the power coming in a bit slower, and if you have room under the hood I'd go for the BW unit. They can be had for about $550 and are nearly bulletproof. Plus if you want more power in the future, no need to upgrade.
were?
were?
#33
Not all s400's will get you into the 9's I would say an s475 on a 1.32 or 1.10 is a great choice and pretty cheap! RPS makes a real nice bov for a 100! I've seen many guys use them. If your trying to build a 100k car then it's not for you but u said budget! http://www.racepartsolutions.com/products.asp?cat=147
#34
