what takes to convert from gasoline to alcohol??
Most efi guys run belt drive pump because the large fuel pumps can't support enough flow at efi pressures. Also you can run ungodly amounts of pressure witj the belt drive to get more flow out of the injectors.
You need bigger injectors
A big regulator if belt drive.
Some way to mount your crank mandrel
a drum of methanol and you are good to go.
I just switched from e85 to alcohol and im liking it so far
