magnum t76 ball bearing oil restrictor?
I going to be running a magnum power t76 BB turbo on a 100% stock lq4 engine. I just got of with tech line and they said I didnt need to run a oil restrictor. Just wanted to double check with you guys here.
look into the oil inlet. If you don't see some sort of restriction in there, talk to a different person at the "tech line".
You might try board sponsor modular turbo.
My big a.. GT47 needs a restrictor. Can't see how your little 76 doesn't.
Check out "Tryme"'s build on syty.net. He has an S trim T76 vs your Q trim.
i always use a t4 feed flange with built in .080 restrictor for all my turbo cars and ive never had an issue.
i get em from amazon, godspeed or whatever cheap stuff is on there like 6-10 dollars a piece, they work awesome
