What fuel pump for stock LS1 with D1SC?
Old 06-16-2012, 06:32 PM
trans damm's Avatar
Default What fuel pump for stock LS1 with D1SC?
What's the pump most used for this setup. Eventually I plan a built bottom end with more boost but I'll upgrade down the road. What pump can I buy now and what will it take me to? I will be using 60lb injectors. What about wiring upgrades? In my Gn I run a double pump and that will safely take me into high 9s especially with meth. Do I need a similar unit for my trans am? TIA
Old 06-16-2012, 08:40 PM
conan's Avatar
If you plan on building the moter and turning it up later I would just do a double in-tank now and forget about it. Just my $.02
Old 06-16-2012, 09:23 PM
trans damm's Avatar
How are people running the second pump, Hobbs switch? I'm trying to go simple right now, but may just do the double pump if it's the only real option.
Old 06-16-2012, 09:31 PM
LS1RedZ's Avatar
I would just give Lonnie's a call and get setup for a double pump setup. When u build a motor then u can add the lines for the extra power. Just my opinion and you wouldnt be wasting money on a racetronix Hotwire kit just to swap it later.
Old 06-16-2012, 10:03 PM
conan's Avatar
X2 ^^^
I have lonnies double pumper. He takes care of every thing, the wiring kit, Hobbs switch, 2 pumps in stock fuel pump assembly / bucket. You send him your entire sending unit and he mails you back the package. Plug and play easy.
Old 06-16-2012, 10:06 PM
trans damm's Avatar
What's the price/ turn around time?
Old 06-18-2012, 11:36 AM
conan's Avatar
Give lonnie a call for those questions...
http://www.lonniesperformance.com/
Quick Reply: What fuel pump for stock LS1 with D1SC?
