4.8L Turbo Tahoe Sputtering? Q/A
Old 07-16-2012, 07:57 PM
I8UR4RD's Avatar
Default 4.8L Turbo Tahoe Sputtering? Q/A
I have a friend with a 4.8L turbo SUV. It has a front mount 70mm on it. It starts up fine, it drives down the road fine. It has a 4800 stall in it. When you hit WOT, it starts cracking up and misfiring/sputtering on its way up to 4800 rpm. It is as if one the way towards building RPM it has a 2 step. After that it pulls like a raped ape. So basically as long as your around 4800+ in RPM its fine, but on its way up, its crackly. I need to get some opinions on this, so I can make a checklist, as it already has had 27 hours or tuning time spent on it, and two different tuners, and is still un resolved.
Also, when installing the cam on an ls1 car.....and in doing so, changing the stock ls1 chain over to ls2, when removing the oil pump, how are you guys getting to that bolt down by the dipstick tube without jacking it up and dropping the pan out of the way. I did not look at it to well, but that seems to be the route to go.
Old 07-22-2012, 11:28 PM
I8UR4RD's Avatar
tips? ideas? where are my gurus?
Old 07-23-2012, 06:01 AM
Captain Double Post
BOBS99SS's Avatar
http://www.ls1howto.com/index.php?article=23
Old 07-23-2012, 09:23 PM
I8UR4RD's Avatar
Originally Posted by BOBS99SS
thanks man. great link. still need some ideas on this sputtering suv with the FM 76mm.
Old 01-16-2013, 01:12 PM
V-seriesTech's Avatar
(plug wires)
Old 01-16-2013, 01:39 PM
LS1Tech Sponsor
hellbents10's Avatar
Could be any number of things???? Does it still have the 5000rpm PE delay? The truck programs have a lot of PE delays, time, rpm, manifold pressure, and torque req.
Old 01-17-2013, 05:12 PM
I8UR4RD's Avatar
appreciate you guys tryin to respond. that car is long gone. not sure what became of it. ill find out though.
Quick Reply: 4.8L Turbo Tahoe Sputtering? Q/A
