Wideband before the turbo
Old 07-25-2012, 09:21 AM
fastcars95's Avatar
Default Wideband before the turbo
I want to put my sensors between the turbo and engine. How long will the sensor survive on the merge pipe.
I already have two widebands so it would be nice to see what each bank is doing.
Old 07-25-2012, 11:12 AM
123quattro's Avatar
I suppose it depends a lot on how hard the car is driven. This is really the worst place to put the sensor: it's hot and high pressure. Both things will kill it.
Old 07-25-2012, 12:03 PM
DavidPHumes's Avatar
Why....?
Old 07-25-2012, 12:59 PM
TurboBuick6's Avatar
If you really want to know what each bank is doing use EGT pre and O2 Post.
Old 07-25-2012, 02:17 PM
c0ncEpT's Avatar
Can certain sensors not take the heat? I have seen big power guys use a wideband sensor in ever primary only a few inches from the head.
Old 07-25-2012, 03:01 PM
Sarg's Avatar
They probably also don't mind changing them out often!
The heat and turbulence pre turbo will give some funky readings some times. I think the EGT pre and 02 post is a good idea. Some turbo cars have o2 sensors specifically calibrated and designed to go pre-turbo, but they are usually only accurate to a certain point. For instance the Subaru WRX Sti has a pre-turbo o2 sensor, but below about 12.5:1 it gets very inaccurate.
Old 07-25-2012, 03:59 PM
sparkwirez06's Avatar
I believe those are egt sensors and not wideband.
Old 07-25-2012, 04:03 PM
Sarg's Avatar
They have both. The o2 is a little lower in the manifold area, the EGT is in the up pipe. I would not consider it a true wideband, but when switched over to the post turbo side it DOES get a ton more accurate and will read down below 12:1 before there is a huge difference between it and a wideband.
Quick Reply: Wideband before the turbo
