ls1 gto truck manifolds
I used truck manifolds, the driver side manifold, i simply hacked off the flange and welded on a flange, the passenger side manifold was a little more involved, took some building up to get it to exit the way i wanted. Here is my build thread on here with TONS of pics. But here are the manifolds.
I used passenger truck manifold on driver side, cut it off and welded T4 flange directly to it with weld el. I did this to get turbo rear enough to get an air filter in front of it. I put the GTO driver manifold on the passenger side with a 3/8" spacer.
https://ls1tech.com/forums/forced-in...keeping-c.html
