3.8 turbo higher ratio rocker arm
Old 09-24-2012, 10:36 PM
thebeewantsboost's Avatar
Default 3.8 turbo higher ratio rocker arm
hey guys, first post here. there are some killer cars on this site. and some people with a hell of alot of talent. i've got an 01 camaro 3.8/t5. i'm running a grand national turbo .63 exhaust a/r .60 compressor. i got a pretty good deal on some higher ratio rocker arms. they are staggered 1.9 and and 1.7's i believe. i was wondering if anybody here upgraded just their rockers(no cam) in a turbo setup. i was going to keep the stock cam and run the 1.9's on the exhaust side. 1.7 on intake. any comments or opinions?
Old 09-24-2012, 11:30 PM
TurboMark8's Avatar
What are the specs on the stock cam?
Old 09-25-2012, 01:57 PM
duration 182/190
lift .258 .255
ls 115
ic 111 <---whatever that is.
and that's with stock 1.6 rockers
Old 09-25-2012, 08:54 PM
Bill_Ritter's Avatar
I would post this on turbobuick.com They have a section for the series 2 3800 engines and LOTS of good info.
Old 09-25-2012, 10:12 PM
thanx, didn't know of that sight. i did make a post there, any opinions are still welcome.
Old 09-26-2012, 02:11 PM
giiventofly's Avatar
fullthrottlev6.com is your friend. plenty of turbo members.
Old 09-26-2012, 05:39 PM
i'm a member there and i had posted this there a while back never got a response.
did a little research. the stock cam lobe lift is (i)255 (e)258
that makes .408/.413 with 1.6 rockers valve lift.
cam lift
.485/.490 with 1.9 rockers
.459/.464 with 1.8 rockers
.434/.439 with 1.7 rockers
so mine would be .490/.459 or .434. not sure if its 1.8 or 1.7 on the smaller.
Quick Reply: 3.8 turbo higher ratio rocker arm
