best 88mm for under $2k?
Old 11-07-2012, 04:30 PM
96s-10ss's Avatar
Default best 88mm for under $2k?
Whats the best 88mm turbo for under $2k? I need a quick spool. My motor is a 9.5:1 forged ls1. Looking at the turbonetics b.b. t88. Looking to make a little over 900hp with room to grow when i build an iron block motor.
Old 11-07-2012, 04:32 PM
96s-10ss's Avatar
Also what would the difference in spool time be going from a .96 to a 1.15 exhaust housing be?
Old 11-07-2012, 04:35 PM
AutomagicLS1's Avatar
my gt-88 from forced inductions worked very well if your doing a T6 kit. Made 1000hp about the same compression as you with ease
Old 11-07-2012, 04:41 PM
sabastian458's Avatar
Pick up a Borg Warner turbo, either 87mm or 91mm, they are less than $1500 new, and if you pick the right one, you can get it for less than $1000 new.
Old 11-07-2012, 04:44 PM
96s-10ss's Avatar
Automagic, how much was that turbo?
Sebastian, i want something ball bearing i think
Old 11-07-2012, 09:08 PM
baggins's Avatar
Wrong thread
Old 11-07-2012, 09:42 PM
1BADAZZSS's Avatar
Force Inductions Borg S488 here. Has worked well so far!
Old 11-08-2012, 06:18 AM
dschmittie1's Avatar
My S88 from forced inductions is doing well fo me also
Old 11-08-2012, 06:30 AM
venom ws7's Avatar
what transmission are you running unless its stalled auto don't go with 88mm on 346ci you will lose all the fun and mid range power IMO
Old 11-08-2012, 07:05 AM
Turbochargershop's Avatar
That new Precision Billet wheel 88mm is a nice unit for the price, Especially for those with limited space. Just released this month(Nov 1st)
http://www.precisionturbo.net/news/P...r-Released/164
Old 11-08-2012, 07:51 AM
$1249 and I was using the small 94mm wheel. It lit off almost instantly with my 347
Old 11-08-2012, 10:10 AM
96s-10ss's Avatar
$1249 is right in the budget. What are the physical dimensions of the turbo itself. And what a/r is that exhaust housing?
Im running a th400 with a 3200 stall
Old 11-08-2012, 06:02 PM
baggins's Avatar
Whatare the Borg units being spoken of above? 87 and 91?
Old 11-08-2012, 07:00 PM
rotary1307cc's Avatar
That is the same part number as on my standard pt88
Id be buying a gt50-88 if i had the room
Old 11-08-2012, 07:08 PM
MillsMotorvation's Avatar
I'm looking to upgrade now also. Doing a forged 6.0. Good info here!
Quick Reply: best 88mm for under $2k?
