Opinions on gt4202 for 370
Old 11-08-2012, 05:23 PM
rossi89's Avatar
Default Opinions on gt4202 for 370
I am finally able to continue my build and was offered a complete gt4202 setup from a local guy. The setup on his 370 made 804rwhp/854rwtq through a 4l80e on 17psi. The only difference is I will be running a t56. Will this be too laggy through a manual? Is there a better option for the same power levels? Thanks.
Old 11-08-2012, 06:51 PM
rotary1307cc's Avatar
Work good on a t56
It is the equivalent of a 7675 precision but in larger housings
Old 11-08-2012, 07:58 PM
LilJohn's Avatar
Laggy... far from it. Odds are itll go the other way and choke up in the higher rpm.
Old 11-08-2012, 08:05 PM
rossi89's Avatar
Thanks guys for the help. But I just found out about the truck manifold kit huron speed makes and think Im going to slap a pt7675 on it. Just waiting to hear back from them.
Old 11-08-2012, 08:41 PM
Louis's Avatar
The 4202 is only a 74mm, and not a lot of turbine. It's really not adequate.
The 7675 will trounce it, atleast another 75-100 rwhp, but still down on turbine flow.
Quick Reply: Opinions on gt4202 for 370
