Chevelle turbo sizing
My brother has a 71 Chevelle with an LQ9 and L92 heads. It's equipped with a 4l60e and 3.55 gears. Compression is 10.4. He is considering a single turbo build with the hopes of a low boost, low rpm, torque rich characteristics. Is it even possible to find a turbo that spools up quickly, makes plenty of stump pulling torque and still gives you a 600hp motor at higher rpm? While a cam may fix the lack of torque, it won't give you torque and that high a hp correct?
