lq4 turbo build
lq4 turbo build
Alright so right now ive been going back and forth between what im gonna build. Currently im deployed, so ive had alot of time to think about it and i belive im gonna be going with a 1500hd, lq4 4l80e 2wd crew cab. Now with the lots of research and not knowing much about turboing a lsx i got some questions. My goals are around 700hp
My build i am planning:
lq4 stock
arp head bolts
l92 heads
ls3 or fast 102mm intake? idk yet
ls3 blower cam? any other choices that are decent?
t76 or a 88mm turbo
single or twin walbro 255 in tank pumps?
70lbs injectors? be enough?
would be doing a transgo stage 2 shift kit, with a 3200 stall and probally going with a 14bolt rear.
Now is there anything im missing or that i have absolutly messed up?
Thx matt
lq4 stock
arp head bolts
l92 heads
t76 or a 88mm turbo
Thx matt
I personally would go:
lq4 stock
arp head bolts (I like to do the rod bolts as well at that HP)
l92 heads (LS9 Gaksets?)
ls3 or fast 102mm intake? idk yet ( I personally would save the money and just get a LS6 Intake use the spare money for a meth kit or IC)
ls3 blower cam? any other choices that are decent? ( I went with the Bob's Brute force cam)
t76 or a 88mm turbo
single or twin walbro 255 in tank pumps? (for 700RWHP you are going to want twins)
70lbs injectors (Should be fine on pump but 80# will give you more wiggle room. I used 60#'s and wish I just bought the 80# at the time as the price difference isn't that far off verses having to sell mine and get new ones. )
If you want more items you can add I have a build thread going on if you search my "Threads Started"
lq4 stock
t76 or a 88mm turbo
lq4 stock
t76 or a 88mm turbo
lq4 stock
t76 or a 88mm turbo
Sorry forgot the details. Actually I was planning on a tube chassis 63 Vette around 2000 lbs plus driver.
