best cam ratio for supercharger
I'm hoping to eventually get either a magnacharger or procharger (haven't decided yet) and wanted opinions on what heads and cam to get. I'd love to have a great sounding idle and it can be a little more on the aggressive side I'd say since I don't drive it very frequently just the occasional Sunday drive or track day. Any thoughts?
Both superchargers will need different profiles and events to optimize each set-up. The size of the blower, size of the cylinder head, and the intake manifold will determine how much overlap and the events the right camshaft will have.
Try to plan everything else out in your build before you choose a camshaft and then a stall converter if you're using an automatic transmission. This way you don't compromise one thing for another and things are made to work with each other.
Hope this helps.
Hope this helps.
