APS parts?
Old 12-10-2012, 07:11 PM
silversweetZ's Avatar
Arrow APS parts?
Anyone know where I can find the last few parts I need for my TT build? I'm looking for:
2 X Barb adapter #151
1 X 12mm x 1.5 x 9/16 JIC #161
1 X 12/18mm copper washer #145
1 X 28mm x 1.25 x 9/16 JIC #153
1 X LHS oil drain hose #149
1 X RHS oil drain hose #150
1 X 1-way PCV valve #16
These are all from the APS website camaro kit. I've tried calling and emailing New Line Performance and Finish line performance and no one returns phone calls or emails. Any help would be appreciated!
Old 12-10-2012, 08:05 PM
Oh4GTO's Avatar
Here is the 12mm JIC
http://www.mrostop.com/5m12f87omxs-p...FcuZ4AodRTcAbA
You are going to have a harder time finding the 28mm JIC. May need to make some phone calls. Or you can just drill and tap to make life easy.
The drain hose is 1/2" hose. Just get a hight quality hose that is able to take high heat. The hose is a push on type so nothing special there.
You can use this for the check valve. Don't remember if its a 1/4" or 3/8". Just look at your PCV hose that runs from the valley to the throttle body.
http://compare.ebay.com/like/1706076...Types&var=sbar
The copper washers can be found on eBay easily and they are cheap.
Barb adapters.
http://www.suremarineservice.com/fit-014.aspx
Old 12-11-2012, 12:28 AM
Excellent! Yeah, i was thinking i'm going to have to tap and use another adapter for the 28mm one. I appreciate the hook up.
Old 12-11-2012, 01:14 AM
93camaro_zzz's Avatar
The hoses would be impossible to find. They were made specific by APS, who does not like to help out Fbody customers at all. That one way hose thing is hard to find too, because the APS one is metal, and all I could find was plastic ones.
I would look in to custom making your own return hoses. I did it myself on my APS Fbody. I just bought a
(2) - 10AN turbo drain fitting for Mitsubishi 20g cartridges
(2) - 10AN 90 degree fittings
about 2-3 ft of 10AN braided hose
(2) - 3/8"NPT to 10AN male adapters off of summit racing.
Voila, you have steel braided drain hoses.
Here is a picture for reference:
Old 12-11-2012, 09:40 AM
Toxic-Evo's Avatar
that looks nice.
try DKT?? they are big into the APS stuff. but i think you should put a scavage pump on it. just my two cents. i know DKT sells a kit.
Old 12-11-2012, 10:40 AM
I have a scavenge pump for it already. I just thought I could get rid of that whole setup with just a gravity drain like the APS kit. Mine is actually a brand new Incon Stage 3 kit, I just hate those oil drain cans, they only sit about 3 inches from the ground when my car is on the floor.
Quick Reply: APS parts?
