another 5.3 turbo build, have a few ?'s.
I am looking to buy a 5.3 next week and ran across an 02 5.3 for $300. The only problem it has low oil pressure but ran good otherwise. I am going to change the cam anyways to a TU1, LS6 or Comp grind with Brian Tooley spring kit. I plan to go thru the engine, I think it's just the cam bearings b/c this came out of a friends suburban. I also found a 2005, for $900 at a local salvage yard with a warranty so which should I buy? I am going to put LS9 headgaskets, headstuds, 80lb injectors, on3 76mm turbo, truck manifolds, LS1 intake or truck intake, have both & alky injection. I would like to go with a built Glide but don't know how well it will work on this combo or Th400 haven't decided yet. This setup is going into my 95 Transam that already has a Fab 9" rearend, antirollbar, 40 spline axles, full suspension, BMR K-memeber, upper and lower a-arms, 8.50 rollcage and weighed 3,200lbs with the old n2o combo. I have since put Aerospace brakes and removed another 100+lbs. I also have a Precision 4k converter that was tight on my old setup so it should work well. I don't know if I need an intercooler with alky injection? I plan on running C12-16 at the track on 20psi of boost. The car will be street/strip but limit boost to 10psi on the street. I also don't know if I should go with stock LS PCM or MS@-3 for fueling and ignition. I am also looking for a budget wastget and blowoff valve. Here is my car. http://www.gmhightechperformance.com.../photo_05.html
Thanks for any help.
I am buying the ebay studs so thanks
The engine had a bunch of miles, like 200k so I was either going to buy rods/pistons or upgrade to the 05+ parts. I am thinking about just biting the bullet and going with aftermarket parts except for the crank.
Yes, I know the 05 engines are better from the factory thats why I dont know if I should buy the other engine or just upgrade the 02 5.3 with the $600 I would save by buying it?
