Stock PCV valve take boost
Old 01-23-2013, 02:39 PM
yttz's Avatar
Question Stock PCV valve take boost
The stock PCV valve is a check vlave by design. You can see this by trying to blow in one end. Anyways, anyone know how much boost it can take before failing?
Old 01-23-2013, 03:13 PM
SSpeedracer's Avatar
PCV is a flow limiter at best. Use a check valve in line.
Old 01-23-2013, 03:33 PM
yttz's Avatar
So you're saying it will fail immediatly? Whats a good check valve able to flow enough with a low enough cracking pressure?
Quick Reply: Stock PCV valve take boost
