any use 78mm LI?
any use 78mm LI?
i was turned onto a s400 base 78mm Low inertia turbo by a friend. forced induction has it i beleive. its very popular with big charger diesel trucks. i was just curious if anyone else has tried one and could give me a review before i buy it.
Great turbo! I have a s480 but that 78 would make some great power on your 370 but by all means go with their 92mm or even 96mm turbine wheel if you can do it. These Lsx engines breathe a ton and you need alot of wheel on the turbine to support it. I have their 87mm turbine on a 347 and I am hoping its large enough
EDIT: btw the ONLY downside to a bw turbo is the physical size BUT easy to work around. They aren't too big
