denmah's commonly bought turbo car items (update 7-11-16)
#570
I went and doublechecked. I got the GT45 80mm billet compressor - not the 88. It is this one:
http://www.vsracing.net/catalog/prod...df0890e864193a
#572
Denmah.
What is your opinion of a stock unported ls2 manifold on a 4.8/5.3 w around 25-30psi build?
I've always put these to the side on turbo builds. Always going for the ls6 or non egr ls1 intakes. Or even the fugly truck intakes
But I'm willing to give it a shot.
Any experience w em??? On a big boost 4.8/5.3
#573
anyone have a link of an fpr with a return that they are using. ebay is fine with me if it works.
also the quick disconnect adapters to hook it all up? not entirely sure what i need to be looking at
#574
Denmah.
25-30psi is arbitrary, everything depends on power you will be making or what to make, dont base any math on PSI
#576
I've seen where a lot of you don't run a BOV with injection, what about blow thru? I'll be running a auto trans. Also, what size nozzle on meth injection on a 6.0 with around 750 rwhp? I was considering building my own, I have a supply of push loc fittings and line, Devil's own seems to have a good price on some of the small stuff.
#577
Thanks again Matt!
Yesterday I ordered 2 micro(mega) squirts LS packages from mike(?) at EFI SOURCE,
Along with some sensors and a 3 bar map's.....
And armed with the confidence you gave me a few weeks ago I did a 4l80e shift kit that is
Working great!
So next is the MS3 install! Along with some Turbo action.
Working great!
#578
I'm currently building an MS3+MS3X because I already had a lot of the parts from prior projects. If that wasn't the case though, I would DEFINITELY be grabbing up one of the Gold Box MS3s with pigtail. What a good deal for what you get!
Is that what you prefer Matt, assuming it's a build with all of the bells and whistles where a micro won't quite cut it?
