wastegate vacuum hose/ rear mount
Old 02-19-2013, 01:00 PM
wild1100's Avatar
Default wastegate vacuum hose/ rear mount
Ok do I run my line from my wastegate to the compressor on turbo or manifold. If to manifold do i just block off barb on compressor. Also its a rear mount if it maters
Old 02-19-2013, 01:35 PM
HRHohio's Avatar
Mine is t'd off the compressor.
Old 02-19-2013, 01:48 PM
runsfromdacops's Avatar
i have the bottom port on my wastgates going to the the turbo housing. but i have my boost controller sensing boost at the IM.
so basically i have mine setup to control the boost that the motor sees but useing the higher pressure at the back of the car to help hold the gates closed
-alex
Old 05-10-2013, 11:02 PM
JoshuaGrooms83's Avatar
im wondering which way i should do this as well. having some boosting issues and not sure which way to do this. still, i got 345RWHP pushing 3ish PSI lol
Old 05-11-2013, 10:30 PM
wild1100's Avatar
I am running a vacuum block off my brake booster line. Seen 10lbs easy with my rear mount no issues
Old 05-11-2013, 11:25 PM
yeah, i had it set up like that at first but due to not building boost, i tried it directly at the compressor without any luck
Quick Reply: wastegate vacuum hose/ rear mount
