Anyone know the exact size T-Bolt clamp for Fbody procharger kit?
Thread name says it all. Need to swap my worm clamps for T bolts for the extra clamping force to try to avoid blowing off charge pipes. Not sure exactly what size and the car is not any where near me to be able to grab a pipe and coupler and test fit it.
Planning on ordering online so links are fine if you have a cheap place to grab em. I was look @ RPS
The pic on brute speed shows 3" inch pipes all the way until you get to the MAF / TB, then it goes to what ever your running... SD or MAF. I just had to buy a 4" to 3" straight coupler to join my throttle body to 3" plumbing, so I know the stock TB mouth is 4". You'll have to get a measurement of you 102mm, might have to get a 4 1/2" to 3" reducer.
Here is where I get my clamps / silicone from.
http://www.turbofittings.com/
