Anyone do a turbo in 67 camaro
Looking to put a turbo in my 67 camaro. Looking for 600 to 700 hp. I have a ls2 in the car now. Has a cam and 92mm throttle body, 4l70 trans. Looking for some help, headers, turbo size, who should i speak to. I can also fab up a set of headers as well.
Thanks
Thanks
1 5/8 headers (manifolds will work too if you want easy), a Turbonetics 7675 with the 1.15ar will work well if its a mild street car like it sounds, 2 1/4" crossover, 4" downpipe, single Precision 46mm wastegate. Should make 600whp at around 13-14psi though that trans if everything is right. Dont expect the 70E trans to last too long. They shift like **** and burn the 3/4 clutches pretty quickly.
