turbo question....thoughts??
Old 04-05-2013, 10:35 AM
burbalanche's Avatar
Default turbo question....thoughts??
What do you think about an s467/83mm turbine 1.10a/r on a 6.0/t56 on e85? This is going in just a fun truck,not for drag or tryin to set records.i know its not ideal bit i can pick this up for a pretty cheap price and just trying to see how everyone would think it would be.. thanks
Old 04-05-2013, 10:40 AM
Sarg's Avatar
I think I would do the s475 with the 96mm turbine instead. I think that turbine is tiny for a 6.0 motor. The 96mm should be the same price.
Old 04-05-2013, 12:19 PM
Would i still have fast spool and response with th 96 though? Seems like i would have some good lag.this is t4 also
Old 04-05-2013, 12:27 PM
Sarg's Avatar
There is a guy with the same turbine and a 80mm borg that has full boost by 3200 rpms....don't know how quick you want it, but on a 6.0 I would not choke the motor like that.
Old 04-05-2013, 12:32 PM
U cant get the 96 wheel in a t4 though
Old 04-05-2013, 10:51 PM
Sarg's Avatar
Why would you want to?
Old 04-06-2013, 10:22 AM
u had said u rec. the 475 with 96 wheel but they dont offer it in a t4 flange which i already am t4.
Old 04-06-2013, 01:27 PM
Sarg's Avatar
So cut it off and weld on a t6 flange. Or put on the tiny turbine with the tiny compressor and be out of steam by 5000 rpm if not sooner.
Quick Reply: turbo question....thoughts??
