Blew up my Turbo 6.0
Old 04-14-2013, 05:22 PM
smokin03's Avatar
Default Blew up my Turbo 6.0
So a rod let go and made a hole in the block and pan in my LQ4. I have a 5.3 shortblock thats been sitting on a stand but apparently its an 2007 flat top 5.3 w/ AFM/DOD. So I guess I need to delete the DOD ..get a few more lifters, lift trays . Do I need to change the vally cover ?
Also i have 2 cams but dont remember which is which they are supposed to be 07 c6 & 06 Zo6 where can I check the Cam #'s.
3206 s20 7061 ..single bolt
06906l 1251 7552 21 ....3 bolt
Also I was wondering if I could put my 317 heads on it and what it would make the compression since stock its 9.9:1
Old 04-14-2013, 05:35 PM
smokin03's Avatar
I think its an LY5 or LMG but the block says R27 and L27
Old 04-14-2013, 05:49 PM
dudeman's Avatar
that sucks. what happend to the old one? to much boost? rpm?
pics of the rod that let go?
Old 04-14-2013, 05:56 PM
quik67's Avatar
Its probably a LH6.
Yes the valley covers are different.
My compression with my flat top 5.3 and 862 heads
comes real close to 10.3 , so you should be around 9.5 .
Old 04-14-2013, 06:10 PM
smokin03's Avatar
blow thru carb 15 psi 15° on 93 w/ a/w.. been running the engine for 3.5 yrs now and it finally let go. I think it leaned out, I didn't see anything on the plugs or pistons detonation wise ill put up some pics
Attached Thumbnails Blew up my Turbo 6.0-10-18f19c12-945281-1280.jpg   Blew up my Turbo 6.0-10-268537ce-1149466-1280.jpg   Blew up my Turbo 6.0-12-8060a249-785258-1280.jpg
Quick Reply: Blew up my Turbo 6.0
