Tick stage one or two turbo cam's
Old 04-28-2013, 10:42 PM
mightybird's Avatar
Default Tick stage one or two turbo cam's
What cam would be better for 76mm turbo ! Looking for a tried and true cam !
Old 04-28-2013, 10:43 PM
mightybird's Avatar
Engine is a 5.7
Old 04-29-2013, 12:08 AM
jridenour31's Avatar
Need more info, specific turbo, trans, weight, goals.....
Old 04-29-2013, 01:17 AM
mightybird's Avatar
3680 lbs if I had to guess! Auto trans ,650 plus horse powe ws6
Old 04-29-2013, 01:40 AM
chiaj144's Avatar
Why don't you call the man who makes them? He would know better than anyone.
Old 04-29-2013, 08:11 AM
MUSTANGBRKR02's Avatar
How do you call someone again?
Is it a street car? Drag car? A 76mm turbo is also very vague. A tc76 and a s476 will require a different cam.
Old 04-29-2013, 10:32 AM
Fail.
Old 04-29-2013, 03:21 PM
mightybird's Avatar
Never mind I called a shop cam is taken care of !
Old 04-29-2013, 03:32 PM
mightybird's Avatar
Turbo is a tc75 was going to use a Cx racing t76
Old 04-29-2013, 03:35 PM
mightybird's Avatar
Sorry tc76 hate this phone
Old 04-29-2013, 05:06 PM
What did he recommend? You're running the 68mm turbine?
Old 04-29-2013, 11:08 PM
a-low's Avatar
What cam did you go with? Im thinking a stage 2 for my 5.3.
Old 04-30-2013, 11:36 AM
mightybird's Avatar
Stage 2 cam is what I'm going with. I talked to my tuner about it ! I'm going to see if I can get it ordered along with lifters and trays before I head out of town Thursday .
Old 05-02-2013, 09:46 AM
Sales@Tick's Avatar
Stage 2 is perfectly fine with that turbine, but that's about as much overlap as I'd like to see utilized with that specific turbine wheel.
Old 05-24-2013, 09:57 AM
djt81185's Avatar
Martin,
What do you think of the stage 2 turbo cam combo in a 05 lq4 with stock 317 heads and a tc76 (possibly going larger if I max out the turbo)? A4 with a 3500 stall and 28" tire and 3.89 9"
Dan
Old 05-24-2013, 11:42 AM
BanditDave's Avatar
Guys, do all yourselves a favor and give Martin a call/PM/email about your specific combo. They off the shelf grinds are good, no doubt, but it isn't just about the cam and turbo...
The intake, converter, gear, tire, intended use all have just as big a part. It isn't much more for him to get you dialed up on THE cam for your combo....as long as you stick to your plan...haha. He can get it dialed up for you and out the door in a few days. It is worth it!
Dave
Old 05-24-2013, 11:57 AM
607motorsports's Avatar
I am running a Tick stage 2 turbo cam on my LS6 with a tc7875 and I absolutely LOVE it! You won't be dissapointed.
Old 05-24-2013, 12:34 PM
mightybird's Avatar
sorry for no updates i have sens changed plans ! i talked to martin over the phone and we discussed a custom grind cam with my work schedule its been a pain getting any work done on the car let alone think about staying on track with this project ! also have decided to go with a turbonetics 7875 ! i have some vacation time coming i hope to have a cam installed so i can drop the motor in the car !
Old 05-24-2013, 05:14 PM
Sales@Tick's Avatar
Originally Posted by djt81185
Martin,
Dan
Dan,
With the TC76 it would be a great match with the LS1 Stage 2 Turbo Camshaft. I really need to have our web guy change the description of the stage 2 cam as it is really intended and designed for a TC76 type turbo and not the larger turbine turbos listed.
Dave
Dave,
Thank you very much for the kind words! I have a ton of good shelf cams, but sometimes a custom cam is needed.
This is what I like to hear!!! How is the combo doing?
It's ok I understand life gets in the way sometimes! Let me know when you're ready to pull the trigger!
Old 05-24-2013, 08:19 PM
LT1RAY's Avatar
When did you upgrade to the T7875? I thought you still had the TC unit
Quick Reply: Tick stage one or two turbo cam's
