stock ls2...change rod bolts like the ls1's?
Old 05-05-2013, 09:26 PM
awd-rwd racer's Avatar
Default stock ls2...change rod bolts like the ls1's?
picking up a freshly rebuilt L76(ls2) just wondering if i should change the rod bolts like everyone does in the ls1. its a stock bottom end...gonna have ported 317 heads, ported ls6 oil pump,HD timing chain, brian tooley valve spring kit, hardened push rods, and tick turbo cam. running a master power t76 turbo.
anything else i should do while i have the short block by itself.
Old 05-05-2013, 09:27 PM
babbage1109's Avatar
its one of those things that if you can you might as well. insurance to say the least. katech direct replacement rod bolts
Old 05-06-2013, 12:32 PM
skinnies's Avatar
They will be fine, don't change them.
Quick Reply: stock ls2...change rod bolts like the ls1's?
