EBoost Street with HPA
it would run like a CO2 setup, it would BE a CO2 setup..lol
my issue would be... with no turbo pressure feed... how would you actually regulate boost spikes and the like? one of the features of the Eboost street is the over boost protection. seems like a neat way to do things but seems to be lacking in a few details.
I would try the two port single solenoid configuration but I'd run turbo pressure to the bottom of the gate and then just co2 to the solenoid no tee that way you have pressure to open the gate and the co2 to control the top. And the over boost should still work because the controller should still be hooked to the manifold to read pressure and make corrections
All u have to do is run the line off the turbo tobthe bottom port of the wg and run the hpa line to the solenoid and then to the top hat.
Just a fyi. Most guy that run on co2 set the reg at about 50psi. But alittle less might work better for u
