370ci LS setup, lsa heads, in a 3400 lb car
Looking through many turbo choices and quite honestly I do not know where to start with all the turbo options.
I have a 370ci setup with lsa heads, ky turbo t4 hot side, a2a intercooler setup going in a 3400# auto car. The car will mostly be on the street... I want a bad ************ on the street. With that being said, where would you start on turbo sizing. Not looking for a power number, but would like the car to run low to mid 9's on race gas. Plan on gearing the car 3.23 with a th350.
I am for any info I can read on, or open to any opinions. This is in the early stages, so any help is appreciated.
I have a set up just like what you are wanting to build. I have a pt88 turbo with a upgraded wheel. No power numbers yet, just got tuned tonight on 15 psi, 16* timing on 93. More boost and meth tomorrow. I will let you know dyno numbers Wednesday and track numbers next week.
3400 lbs you can get low to mid 9's on pump gas
Mine weighs 3950 and went 10.0 @ 137 with 1.6 60 and basically no 2nd gear. Standard s475
Lighter weight and better launch and your at your goal
