61/.96 on3 turbo on a lq4 good-bad-or do it
what can i expect from these turbos on a stock LQ4 / 6spd w/ 327 gear - got them from a friend and looking to make 5-600 whp in my street 68 camaro want to run pump gas not e-85 and using air to air intercooler & coolingmist water/meth kit.
new to the turbo world thanks for the help.
Stacy
Stacy
When you say "these turbos" do mean more than one? If you add a second one that goal will be easy. A bit too small as a single for a lq4.
edit: Just seen you said "them" so I guess you mean 2. That would work for your goals
Yes twins
Im hoping for low spool and 10-15#s of boost without choking the motor is why i looked at these instead of going with a smaller .68AR housing and if it doesn't spool by 2000-2400rpm i will get martin to spec me a cam with more exhaust to compensate for the large .96AR. (unless thats a bad idea)
will 3" coming off the turbo and tie it into my 2.5 flowmaster full exhaust be ok.
