junkyard t76 5.3 ring gap?
Old 06-11-2013, 09:32 AM
samtodd's Avatar
Default junkyard t76 5.3 ring gap?
You guys running turbo 5.3's are you changing ring gap at all?
Old 06-11-2013, 09:42 AM
oange ss's Avatar
how much boost ?
Old 06-11-2013, 09:52 AM
Troy5061's Avatar
Iirc .028-.030.
Old 06-11-2013, 09:53 AM
GTO Eric's Avatar
^^^and how many miles on the engine?
100k+ leave em alone.
Old 06-11-2013, 10:06 AM
samtodd's Avatar
Not alot.. It will sit around 7 or 8. might bump it now and then but its a DD.
Old 06-11-2013, 10:07 AM
samtodd's Avatar
and will probably have around 100k..
Old 06-11-2013, 10:16 AM
oange ss's Avatar
def not .028-.030, i would leave them be at that boost level
Old 06-11-2013, 10:22 AM
samtodd's Avatar
cool thanks!
Old 06-11-2013, 10:48 AM
boostit5.3's Avatar
im currently spraying the **** out of mine to loosen the rings up for the turbo
Old 06-11-2013, 07:28 PM
9 Second Truck Club
stock48's Avatar
A 100k mile engine should be fine. If low miles and running pump gas you could have a prob.
Old 06-12-2013, 02:52 AM
silversweetZ's Avatar
I didn't take the chance, I gapped mine to .028 and plan on running 12-15 lbs
Old 06-12-2013, 09:13 AM
SS2win's Avatar
ditto except I went to 0.025. I found my 87k mile 05 L33 ring gap was 0.015 before decarboning and 0.020 after. second ring was left alone as they measured 0.029
EDIT: I would leave it alone for your boost levels.
Old 06-12-2013, 09:29 AM
Compressor Surge's Avatar
I'd leave it alone. I gapped mine, but crushed ring lands long before the rings even thought about butting.
Old 06-12-2013, 10:11 AM
samtodd's Avatar
any idea how much boost is safe with leaving gap where it is? 12 lbs? more?
Thanks
Old 06-12-2013, 10:30 AM
I ran my old 5.3 with an S400 to around 14 psi with stock ring gap, and it was never a problem. BUT, like these guys have been saying, it was an old wore out turd.
Old 06-12-2013, 11:32 AM
chiaj144's Avatar
60k on my L33. Has seen 14lbs for just over a year on stock gaps. Soon to be 20lbs or so.
Old 06-12-2013, 02:03 PM
CameronVic's Avatar
I aimed for .032 on mine, but ended up with about .035 (upper and lower) because I went fast. E85, 5.3, meth, 17-18 psi. I don't mind some blowby coming out of the breathers, it makes it look like I take time to armor all under the hood!
Old 06-12-2013, 10:55 PM
tonytone4143's Avatar
how about new rings?? what would you gap them to? same dd and -lbs..
\sorry to jack your thread.
Old 06-12-2013, 11:17 PM
oange ss's Avatar
.022 would be pretty safe
Old 06-13-2013, 08:23 AM
got-a-ls1's Avatar
110k mile 5.3 (although i question if the engine was replaced before salvage cause it was so ******* clean). i ran 18-20psi with meth injection and never touched the gaps (the water helped pull heat out as well) ran for 6k miles and it loved it. only killed it with a miss shift.
Quick Reply: junkyard t76 5.3 ring gap?
