part number on 62mm procharger bearing
Old 06-12-2013, 08:46 PM
baycityrides's Avatar
Default part number on 62mm procharger bearing
anyone happen to know the part number off of the inner 62mm high speed bearing inside of a F1a procharger? from what i understand is the same as the D1, and P1. the stainless allen that hold the retainer in is being a mother and is at a machine shop getting removed. i want to order this last bearing before its done so that when its re assembly time i have everything! someone out there must know the part number and procharger wont tell me anything I ask this because i have sourced a bearing supplier that pretty cheap for me!
the other high speed bearing on the shaft is a 40MM and incase anyone ever needs to source one heres the part number S 6203 C TA A7 its a GMN brand and is 17mm ID 40mm OD 12mm thick
Quick Reply: part number on 62mm procharger bearing
