Looking for the right turbo cam
First I have a new setup going together and I have a few goals I'm trying to meet in the cam. I will be ordering something within the next week so
New combo
Forged ls2
Prc 255 ls3 aftermarket castings
Stock ls3 intake
92 mm tb
2000 cc injectors
Th400
9inch
Currently have a 7675 turbonetics but will be swapping in a pt88 or something similar later in the summer
On e85
"I'd like a near stock idle "
Make peak power at 6400-6500
Like to see 750 - 800 rwhp at or around 15 psi
Just wondering what you guys would recommend
New combo
Forged ls2
Stock ls3 intake
92 mm tb
2000 cc injectors
Th400
9inch
On e85
martin at tick would be my suggestion!
-Casey
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
TWITTER @HURONSPEED
Here is what I would recommend for your set-up:
226/235 .605"/.610" 115+5
You have a fairly large motor for that turbine wheel, and we need to stretch the exhaust valve opening event to an earlier opening so that power can continue to climb after horsepower peaks. Since the turbine wheel is going to restrict power production past 5500rpm, this must be done in order to ensure a wide power band and so that power doesn't fall off the face of the earth after horsepower peaks. We want a nice flat curve after horsepower peaks and for it to slowly fall off. If the exhaust valve doesn't open early enough this will not happen and you will have a very peaky power band. Average power will go up as will peak power.
That said, your cylinder heads will help to carry power further into the RPM range as well since the intake port has a fairly large amount of cross sectional area and because of the large intake valve as well. We just need to shape that curve with exhaust events to what I know works best in these types of set-ups.
This cam only has .5 degrees of overlap @.050" lobe lift so it will have the "near stock idle" that you requested. Hope that this helps you in your decision making.
As far as the PT88 later on down the road, this cam would work just fine with it also.
