Simplified Catch Can Set Up
Old 07-22-2013, 03:59 PM
Wicked69's Avatar
Default Simplified Catch Can Set Up
I know tons of threads. None answer my question. I currently have a typical set up. Rear drivers side valve cover, passenger front valve cover to a single can. This set up sees a lot of oil as well as condensation. All the oil is gravity fed to the rear. I was wondering if it would work to run a fitting at the front of each valve cover and to its own catch can? So 2 seperate catch cans. It seems as though the can would see condensation only and I own a second can. Just cap the drivers side rear valve cover and cap the exit side on each catch can.
Quick Reply: Simplified Catch Can Set Up
