How to run a return line threw the evap ?
Old 08-21-2013, 05:46 PM
Hulkls1's Avatar
Default How to run a return line threw the evap ?
Anybody have pics? I'm running stock fuel rails . Can some one tell me how this is done??
Old 08-21-2013, 06:02 PM
SPRAYED 01's Avatar
I don't have pics but I can explain. On the driver side rear by the fuel filter is a block with fuel lines going to it. One of them goes back to the sender as a return.
You need to remove that line and plug the block. Then just simply move the evap line at the sender over to were that line used to be.
You obviously need fuel rails with a return. The 97&98 c5 vette rails have a return. That's what I used. You can even put a 1:1 regulator on the factory rail.
Old 08-21-2013, 06:13 PM
Hulkls1's Avatar
Where can I get the 97 fuel rails?
Old 08-21-2013, 06:22 PM
SPRAYED 01's Avatar
I actually have one for sale with the regulator. Pm if interested
Quick Reply: How to run a return line threw the evap ?
