divided turbo on undivided turbo manifold
Im buying a trick performance turbo manifold and its a undivided flange. The turbos I been looking at has the divided flange on the turbo. Question is can I put the divided turbo on a undivided turbo header flange?
The short answer is yes you can. I have been looking in to this for a pair of Borg warner s366 . The ar for the divided .91 should be smaller than the open .88 and should spool sooner . This is theoretical and has been proven on 4 cyl. applications. Such as a test on a s2000 with a back to back test. The only issue that may arise is choking in the top end.
