New~ Stainless V-banded "Truck Style" Manifolds!
New product to help those DIY kit builders, or for those looking to enhance their current set-up with a nice set of v-banded manifolds without the hassle of having to modify cast factory manifolds!
http://www.shop.huronspeedproducts.c...s-truckman.htm
Designed after the ever popular "truck manifolds" for 98-02 LS1 f-body Turbo Kit applications. These come in a stepped header design to maximize flow, give great appearance, great strength out of Stanless Steel, and V-banded connections for ease of fabrication!
These are a great choice for those wanting to build their own turbo set-up or modify their current kit to utilize a V-banded manifold without the hassles of modifying a cast truck manifold and deal with welding the tricky cast.
Features:
Complete Stainless Steel, fully polished for a great look!
2.5" V-bands with step for perfect alignment
Stepped runners for best performance and flow
45mm-51mm-63mm Stepped Runners
1 Year Warranty against any issues!
Standard pricing is set at $450 per set
LS1tech intro pricing set-up at $395 SHIPPED for the set through the end of September!
Order your set here: http://www.shop.huronspeedproducts.c...s-truckman.htm
![](http://i833.photobucket.com/albums/zz253/Oh-Check/Oh-Check004/OCHECK1-1_zpscf69ec07.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/Oh-Check004/OCHECK2-1_zpsb7b572e9.jpg)
Features:
![](http://i833.photobucket.com/albums/zz253/Oh-Check/Oh-Check004/OCHECK4-1_zpsf84cb8fe.jpg)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I so hope these pan out and arnt like the past thin wall cracking junk. I like the stepped and the v band. If flange and wall thickness along as type of stainless pans out ill definatly take a set.
would there be anyway to get these in mirror images of the drivers side? I'll be running a twin setup with the manifold flipped forward. I like the exit angle of the driver's side flipped better than the passenger side flipped.
IMO if you guys want to hit a home run take the factory truck manifold and create a CNC program to machine the V-band out of the stock flange (there was a guy on here that did that) that would sell like hotcakes.
The comment "V-banded manifold without the hassles of modifying a cast truck manifold and deal with welding the tricky cast" does not hold water, the stock manifolds are CAST STEEL and very easy to work with.
Not bashing your product just give you my .02 from a customers prospective.
