427LSX - AFR Heads What Rockers?
Old 09-23-2013, 11:17 AM
Patsy57's Avatar
Default 427LSX - AFR Heads What Rockers?
so im looking to put down between 800 and 900 wrhp and my setup consists of:
LSX Iron Block
Diamond Forged Pistons
Blower Cam
AFR 225 Heads
Oliver Billet Rods
Callies Crank
ProCharger F1r - 15 to 20PSI of boost
so that being said I am looking to replace my Rockers, Valves, etc while the motor is all down. I have looked at Jessel rockers and T&D but they are a ton of money and not so sure needed in my application. What do you suggest for Rockers? I want adjustable rockers, and Im leaning towards YT but wanted to see what you all thought?
Let me know your thoughts, especially with the boost I will be running. I havnt worked out the cam specs yet either..
Thanks!
Old 09-23-2013, 11:33 AM
c0ncEpT's Avatar
Do AFR230's require shaft rockers?
If they don't why do you want adjustable rockers?
With a hydraulic roller stock rockers will work to 1000+ hp and 8,000 RPM.
Old 09-23-2013, 11:40 AM
Patsy57's Avatar
Stand corrected this is a set of 225`s, I would do adjustable to tweak the HP but its not a necessity..
Quick Reply: 427LSX - AFR Heads What Rockers?
