5.3 /4l80e GT45 rear mount S10
Running true duals dumped before axle but I plan on cutting of the mufflers and putting on my magnaflow stainless dual 2.5 inlet to single 3" Y-pipe and having a T4 flange welded on. For oil routing I want to purchase a pre-tapped oil blockoff adapter for the feed and using a shurflo 643-210 scavenge pump to pump oil back into the oil cap. My question is what size piping should I use for the cold pipe to the throttle body? Also how does the GT45 spool up. I only plan on running 12lbs of boost max. Just trying to have a little fun... using a 38mm emusa waste gate and a 50mm BOV. Should 60lb injectors be adequate? I have a 4l80e with a 3200 circle D stall and 3.42 gears. Is there anything I should be aware of? This is my first time dealing with turbos
