engine harness problems
Old 10-20-2013, 02:05 PM
topgun542's Avatar
Exclamation engine harness problems
Alright, so i have a 4.8 going into my camaro, going turbo, anyway, how would i go about wiring this? the truck wiring harness has the fuses all connected, the car is different. and if i go with a fbody engine wiring harness, what pcm can i use. And can it work with all the truck sensors? I have the truck pcm, its a 2006 pcm, but i dont have the car pcm. any ideas will help!
Old 10-20-2013, 07:00 PM
topgun542's Avatar
Its also not a stadalone, i need stock guages and stuff to work
Old 11-12-2013, 12:04 AM
topgun542's Avatar
im gonna bump this and also add, can the truck harness be reworked to work with the 99+ fbody interior harness? im a tad lost
Old 11-12-2013, 08:01 AM
SS2win's Avatar
anything is possible. this link should help get you started. http://www.lt1swap.com/2000harness.htm
after that search is your friend
Old 11-12-2013, 08:57 AM
topgun542's Avatar
Yea I Found That Site Earlier Last Night, Just Never Repinned Anything before
Old 11-12-2013, 11:47 AM
turbo_bu's Avatar
other slight issue that you will need to work out is whether or not you are going DBW or DBC. You mentioned 2006 ... that's a DBW (drive by wire) throttle body. If your keeping the DBC (cable throttle body), just keep the camaro harness and hook it up to the 4.8. Otherwise, going DBW will probably involve a whole nother can-o-worms.
Quick Reply: engine harness problems
