Stock 5.3/6.0 truck heads turbo 700hp
I built a Gen iv 5.3 with stock 243's, added Harland sharp rockers, LS7 lifters, push rods, ARP head studs, ARP rod bolts, 96lb injectors, custom grind Cam, LS9 gaskets, Fast 102, T-76, running E85 through a 9" and a TR6060. I am expecting to be in the neighborhood of 700RWHP running a good amount of boost. Will post solid numbers when she goes to the dyno.
9 Second Truck Club
Several different ways but a Simple combo would be: S475, Intercooler, JFR Isky triple 12 cam, pac or Isky valve springs, 91 oct and meth inj, or E85. Head studs, and LS9 gaskets would be a good idea. As said above it will prob take 18~20 psi of boost with the lower compression. A Customer of mine today with a stock 317 headed lq4, S475, triple 12 cam, on 91 oct/meth inj @15 psi go 727 thru a 4L80E on a conservative tune.
