zl1 intercooler pump pigtail
Old 11-02-2013, 07:55 AM
rp0029's Avatar
Default zl1 intercooler pump pigtail
In the final stages of slapping a zl1 blower on my lq4 in my 68 camaro. Mounted the intercooler pump to the frame rail, but does anyone have a part number for the pigtail to the pump or know where I can get one?
Old 11-03-2013, 01:47 PM
droksformula's Avatar
Try lingenfelter performance, as they did a test with multiple ic pumps. They should know where to get it if they don't have it themselves.
Old 11-11-2013, 03:03 PM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default ZL1 pump connector
The last time I checked (a month or so ago) GM still didn't have the service connector available for the ZL1 pump.
These are the part numbers from the GM service information:
•OEM Connector: 9408621
•Service Connector: 19300589
When we did the ZL1 pump testing we made our own jumper harness in order to be able to do the testing and connected directly to the terminal pins.
I think the Volt uses a similar pump (same connector) for electronics cooling but it doesn't show a service connector part number.
The only place I have seen the connector for sale is on the GMPP LSA crate engine harness (expensive way to get it).
Hope this helps.
Quick Reply: zl1 intercooler pump pigtail
