those with huron a/c turbo kits
i tried searching but i was wondering what did everybody do with the front swaybar? did u guys removed it or is there a spacer kit? Im thinking of this huron turbo kit but i have a strano 35mm front swaybar and i was wondering if that would be in the way
LS1Tech Sponsor
Sway bar was not intended to be ran with this kit. If you wish to run one, you would need to space it down as you mentioned to clear below the hotside piping. Due to the thickness of your sway, I am not sure exactly how much you would need to space it down, but during install this is something you could quickly measure, and then using some square stock of this height make a spacer for it!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
