T-Netics RG-45 wastegates.. question on adjustment
Im running the TC66 turbos, and i have twin T-netics RG-45 wastegates. They have a pre-load screw on top of the gate. the manual reads for every 2-3 turns, it increases the spring pressure 1psi. so, i have an 11psi spring in there now, and i want that to be my minimum boost. Do i just back the set screw out to where its not putting tension on the gate spring anymore and roll with it? Ill be on a an eboost2, and will push the setup to about 23ish, psi.
