twin 5.3 converter
Yank makes an AWESOME converter, as does Circle D.
If you want to retain lockup, a multi-disk converter is recommended. With a single disk at wide open throttle, bad things will happen if the converter tries to lock.
You can still get away with a single disk as long as you don't lock in the first three gears.
