370 or 408?
370 or 408?
Trying to decide between the two on my turbo build. Going to use a dragon slayer crank, good rods and pistons, stage 3 243s and shoot for 10-1 compression. The turbo is a s480 billet wheel, ultra cover, 1.58 ar. Custom cam, ptc stall, 1.69 glide, holley high ram, 417 motorsports intercooler, holley dominator efi, billet atomizer 225s. Race weight will be right around 3100.
I originally planned on a 370 but I could pretty much do a 408 for the same money, does anyone prefer one over the other and why? Thanks.
408 will always make more power than a 370.....but, you will find that you run out of turbo much sooner on a 408 than a 370...
so if you dont want power to flatline and fall off early, you have to use a bigger turbo to begin with...which means slower spooling...not necessarily a bad thing
and 408's love a twin turbo setup
and remember...
boost just tells you how much restriction you have...
it doesnt dictate how much power you can make
10 psi on a 370 might get you to a good power #
but 10 psi on a 408 will always be more power than the 370
with a 408 you can get to the same power # as a 370 with less boost
and remember...
the setup should be good for over 1000 at the wheels. the turbo is rated to 1400, going to run a aeromotive pro series that's good for 1700 forced air efi. It will be on c or q16. Im wanting to keep a stock deg head and I know there are better ones out there but for the deal I got on these and how well the flow im going to use them for now.
