these sufficient for twins?
Im looking at buying 2 turbonetics 60-1 hifi's with probly .68 t4 oncenter (I know tangental is way better flow ).
Im leaning towards building a twin low mount kit simalar to the aps kit but im mostly concerned about packaging and power.cars a 98 camaro m6 with a 2005 ls6 with a tick turbo cam.im planning on around 600-700 whp for when I do highway pulls with room to grow for an eventual forged motor but also want fast spool. Car is 99% street
I figured on center would make packaging easier from looking at BBOO"SS"T thread. But 60-1 are pretty compact, I found the dimensions on tnetics website. I talked with someone local that runs a tti tt kit on a c5 that makes close to 1k.im now entertaining using t3\t4 with the hpc 61 wheel with a e cover and f1-62 turbine vbanded inlet and outlets with .85ar. I think they will be pretty damn efficient and give instant spool.i know said vette has pretty much the same turbos minus a 58mm compressor.
If you're planning on a forged 347, I would just go with t3/t4 and either go 62 or 65mm turbine wheel w/ .85a/r turbine housing, and maybe go with the optional HPC wheel and that would make it pretty responsive. But if you're building a stroker motor, I would go straight t4. and still go with HPC(billet) compressor wheel. And another thing, I would'nt go with the on-center turbine housing, I don't think it would matter much as far as packaging them.
Awesome thanks for the input man.when I go forged it will be a 347 most likely. I think the t3\t4s I am thinking of should be good. May just go with the 58mm compressor. Seems turbonetics has the billet hpc wheels on back order 8-10 weeks . Hopefully ill be able to get the car driving by mid april
